Contact Form indicates that t working however no email is received.
Thread begun 12/20/2014 7:20 pm by bob.lee357763 | Last modified 12/23/2014 7:04 am by Jason Byrnes | 1731 views | 3 replies |
bob.lee357763
I have uploaded draft file to http://lithgow.xyz/DL/contactme.php and would greatly appreciate your advice. Regards Bob
Who is your host?
Depending on your host, you may need to set certain options in Universal Email.
Some hosts will work if you leave the SMTP Server setting on the Email Server Tab blank, others will require that you enter the SMTP server address.
Some will work using the standard Mail protocol, other will require that you use the Pear Mail for SMTP, some using Pear mail will require authentication.
Some hosts may require that the from address being used be a valid email address for your domain. Some may require that the option to include the from Email address be passed as an extra parameter.
To be successful with Universal Email, you will need to know the requirements of your host for sending an email using a PHP script.
Also, double check your Spam folder, it is possible that the email is being trapped as spam.
bob.lee357763
  Who is your host?
You haven't answered any of the questions that i had asked
who is your host?
In the UE server behavior, what have you set the From address to?
What are you using for the To Address?
What is the SMTP Server set to, and what port?
Depending on the host, you may be able to leave the SMTP Server setting blank, or you may need to enter a valid address.
Also depending on the host, the from address may need to be set to a valid email address for your domain.
It amy be that the host only supports using the Pear Mail for SMTP method of sending the email.
One thing you can do to help troubleshoot is to add the following code just before the closing </body> tag:
<?php var_dump($_SESSION); ?>
and add this code at line 1 to turn on error reporting:
<?php error_reporting(E_ALL); ini_set('display_errors','on'); ?>
This will show if any errors are occurring and also dump the session contents to the page. The session contents will contain the status of passing the email to the SMTP server.
