I cannot setup a database connection in dreamweaver prior to using PowerCMS. I see no instructions on your website. The one webinar shows setting up local server, but not remove mysql.
Thread begun 12/17/2014 7:15 am by tkendrickmail32213 | Last modified 12/17/2014 10:28 am by Jason Byrnes | 1155 views | 1 replies |
tkendrickmail32213
I am trying to create PowerCMS on an existing website. It intially prompts me to setup a database connection. I have created a mysql database on my remote server and entered the credentials in the wizrd. However, it isn't detecting this and showing nothing but errors.
To create a connection that connects to the remote MySQL server, you first need to configure the Testing Server settings in the site definition to connect to the remote site through FTP.
The DB Connection relies on the testing server settings. if the testing server settings are set to use the local testing server, the Database connection will be made to the local database server. if you set the Testing server settings to connect to the remote server, the database connection will connect to the remote server.
