I have some troubles when I installed Design Extender in using Power CMS
Thread begun 12/17/2014 12:10 am by richard.abitbol263730 | Last modified 12/26/2014 6:17 am by Jason Byrnes | 5481 views | 19 replies |
Since I installed DEsign Extender , it seems I have a lot of conflicts with Security Assist.
What can I do to uninstall all my previous PowerCMS and to use properly CMS with Design Extender
I want to purge my tables and to start properly with the new product.
Can you help me.
I'm not entirely sure i understand the question, but to remove all the Power CMS Tables from your database: delete the tables in the data base who's names start with pcms2_ and kfm_ and also the wa_settings table.
do I need to delete some files or directories ?
There are a number of files and folders associated with Power CMS, too many to list here, it would be simpler to start a new site.
Just a fw of the folders for Power CMS are
admin_cms
install_cms
webassist
WA_CMS
Connections
css
js
Templates
WA_Globals
but some of these folder may contain files for other aspects of the site.
But this site was already used
I have another problem with this: when I use HTLMEDITOR and chose to replace an image, in stead to go to the directory of "image files" , i am redirected to "http://www.compol.info/install_cms/diagnostic.php" I don't understand wwhy ! What can I do.
Can I reinstall properly Design extender
That indicates that the installation has not been completed.
you will need to complete the installation.
how I don't know where it stops. It ask me to set privileges and i don't know to which directory I have to do it
The directory that Power CMS is in needs to have rite privileges.
I get this message when the Login is asked
I don't know what to do since I can't start again from the begining to know what was wrong. I don't know where is the problem with the database
The error message is ERROR: Failed to save the settings in the database. Please verify your database connection.
