if user accidentally hits the continue button when filling out form
Thread begun 12/15/2014 8:45 pm by mycalidesigns | Last modified 12/17/2014 1:36 pm by mycalidesigns | 2561 views | 5 replies |
mycalidesigns
on my checkout when user is filling out billing and shipping info, if they accidentally hit the continue button without filling out the required fields the progress wrapper gets hung up. I would liked for it to check form before going into the progress wrapper upon submitting?
mycalidesigns
Cart is working great just need to fix the progress wrapper.
Sorry forgot to add the link to cart, check PM
Looks like you have a conflicting script.
When i test your page and look in the free bug error console, i see the following error:
TypeError: undefined is not a function (evaluating '$('ul.menu').superfish')
the error occurs in the scripts.js file in the following code:
$(document).ready(function() {
$('ul.menu').superfish({
delay: 600, // one second delay on mouseout
animation: {opacity:'show',height:'show'}, // fade-in and slide-down animation
speed: 'normal', // faster animation speed
autoArrows: false, // disable generation of arrow mark-up
dropShadows: false // disable drop shadows
try removing the scripts .js file from the checkout page.
mycalidesigns
will do please stand by
mycalidesigns
That didn't work, i found these two files causing issue
<!--<script src="SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<script src="webassist/forms/wa_servervalidation.js" type="text/javascript"></script>
Removed and now working great. Thanks for your help.
