finalising questions
Thread begun 12/15/2014 2:18 am by Jamie | Last modified 1/20/2015 9:21 am by Jason Byrnes | 4631 views | 13 replies |
Jamie
Hi Jason
Got a couple of questions finalising an ecart install please.
On this page http://clients.motley.co.uk/iday/cart.php (attached) I have set it so that if the cart is empty, the table with pricing is visible. If you add an item to the cart the table disappears and the cart options become visible. On this page, with the slight adjustments I have made, the 'continue shopping' option now does not go to where it should: http://clients.motley.co.uk/iday/book-now.php What do I need to change to get that working again?
Also, as part of the checkout process the client requires the form from this page http://www.independentsday.co.uk/delegate-details.php to be sent through to them how do I add that to the cart page please?
Jamie
Jamie
see PM
for the first issue, edit line 144 of the cart page:
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'].($_SERVER['QUERY_STRING']?"?".htmlentities($_SERVER['QUERY_STRING']):"");
$_SESSION['WAEC_ContinueRedirect'] = "/iday/book-now.php";
for the second issue, on the delegate-details.php page, save the submitted form to session variables, you can use those session variables on the pp_confirm page to send them in an email or save them to a database.
Jamie
Thanks Jason (for both)
I have recreated the delegate details form and created the session values -http://clients.motley.co.uk/iday/delegate-details.php - how do I now incorporate the form on that page to the form on the cart page http://clients.motley.co.uk/iday/cart.php and then use that info to provide the client with the details? both files attached in case you need them for reference
Jamie
I don't follow, please provide more details.
Jamie
Well the delegate detail form is required as part of the purchase process so I either need to include it on the cart page and when they click checkout validation checks are run and they are taken to paypal or, alternatively, cart works as it is right now and the checkout button takes them to the delegate detail form which, in successful validation, the submit then takes them through to PayPal and all the form info gets submitted to my client.... Either way am not sure how to achieve this
I would set up the delegate-details.php page to save the form entries as session variables when it is submitted,, then redirect to the checkout page
use Security Assist to set up an access rule to allow if one of the sessions from that page is not blank, then add access restriction to the checkout page that redirects to the delegate-details.php page if not allowed.
that way, when they try to checkout, they will be directed to the delegate-details.php by the access rule until they have filled in the form.
Jamie
Sorry Jason, I don't follow/little confused. At what point in the process are you suggesting that the delegate details form is completed?
the flow i am suggesting would be:
cart page ->
user clicks checkout button which goes to checkout page ->
Checkout page has access rule to ensure one of the sessions from the delegate details page is set, if not, redirects to the delegate details page, if one of the sessions is set, loads the checkout page->
so the first time though, it would redirect to the delegate details page, the user would fill in the info, when submitted, save the form to the session, then redirect back to the checkout page.
this time around, the access rule would pass, so the checkout page would load.
