MySqli Insert record
Thread begun 12/15/2014 1:17 am by CraigR | Last modified 12/17/2014 10:33 am by Jason Byrnes | 1640 views | 3 replies |
CraigRBeta Tester
MySqli Insert record - checkbox
I have added a MySQLi Insert record behavior to my form.
If I submit the value of a form checkbox as Checkbox 1,0 when creating the column bindings, when i try and insert a record i get the following error...
Undefined fieldtype c (parameter 5)
the code generated by the server behavior is as follows...
$InsertQuery->bindColumn("AllDayEvent", "c", "".((isset($_POST["chkallday"]))?$_POST["chkallday"]:"") ."", "WA_ZERO");
If I submit the value as integer, the code works fine
CraigRBeta Tester
Hi Jason, not live yet.
Have got around the problem by using integer rather than checkbox, so no biggie
Can you not reproduce ?
No, I'm not able to reproduce. Perhaps you have an older version of the webassist/mysqli/queryobj.php file on the server?
