Delete Record button has stopped working
Thread begun 12/12/2014 3:38 am by Mags | Last modified 1/29/2015 1:13 pm by Jason Byrnes | 5186 views | 14 replies |
Mags
For some reason my Delete Record button on my Results page has stopped working - when you click Delete you get the black overlay and the Delete warning, but when you click Delete it doesn't do anything and the only way to get rid of the overlay is to click Cancel. The record itself doesn't delete. Any idea what might be causing this?
Mags
Hi Jason, details in PM section, thanks.
see pm
Mags
See PM.
it wasn't so much that the delate record behavior is not working but code order.
the recordset was populated on the page first, then the delate behavior came after it. this meant that the result was created before the record was deleted. If you refreshed the page, you would've seen that the record no longer existed.
i moved the code for the delate behavior so that it came before the recordset so that the delete would happen first.
Mags
See PM.
See PM
Mags
Whoops - thanks!
you're welcome.
