online connection seeking LOCAL connection info
Thread begun 12/10/2014 7:43 pm by beaded | Last modified 12/15/2014 9:47 pm by beaded | 955 views | 2 replies |
beaded
The site works locally, but online, a search produces this:
Warning: require_once(Connections/cakelocal.php) [function.require-once]: failed to open stream: No such file or directory in /home/liscam11/lisascakestand.com/products_results.php on line 1
Fatal error: require_once() [function.require]: Failed opening required 'Connections/cakelocal.php' (include_path='.:/usr/local/lib/php:/usr/local/php5/lib/pear') in /home/liscam11/lisascakestand.com/products_results.php on line 1
I used Webassist's dynamic connection interface and believe I used it correctly.
The search and related files uploaded:http://lisascakestand.com/products_search.php
the error means that the connection file has not been uploaded to the server.
this file:
http://lisascakestand.com/Connections/cakelocal.php
needs to be uploaded
beaded
I deleted the database in the web sire control panel, created a new database, then, in making the dynamic connection setup, I made the LIVE connection the primary and the LOCAL connection the additional. It works. Thanks.
