Security Assist Select a Rule
Thread begun 12/10/2014 10:15 am by Mushroom-Graphics | Last modified 12/10/2014 11:52 am by Jason Byrnes | 1947 views | 3 replies |
Mushroom-Graphics
I have a details page where there is a field populated by a checkbox in the update/insert forms asking if a product is active. I want the word "yes" to show up if the value for the 'isactive' field is '1'. I used security Assist>Show Region and created a rule:
Allow if <?php echo $row_WADAproducts['isactive']; ?> = 1
When I try running it I get this error:
Notice: Undefined variable: row_WADAproducts in C:\xampp\htdocs\officefurniturezone.com\webassist\security_assist\helpergroupsrulesphp.php on line 8
The one shows up fine in the page so I know the variable is there within the Query and page so I am missing something:
The helper...php file line looks like this:
switch ($ruleName){
case "Show If Active":
$comparisons[0] = array(TRUE, "".$row_WADAproducts['isactive'] ."", 1, "1");
break;
return $comparisons;
Thank You
This is not the way to go about this.
instead of using a security assist access rule and security assist show region, use the WebAssist Show Region utility.
in design View, type yes where you want it to show, then select it.
in the server behaviors panel, click the plus button and select:
WebAssist -> Utilities -> Show Region Utility
IF: Click the lightning bolt icon and select the isactive column of the WADAproducts recordset.
Is: Equal To
Value: 1
Mushroom-Graphics
Thank You
you're welcome.
