redirects after ogin
Thread begun 12/10/2014 9:52 am by Sweens | Last modified 12/12/2014 9:55 am by Jason Byrnes | 4997 views | 14 replies |
Sweens
Hi
I have a page that records login stats and creates loads of session variable depending on the SecurityAssist_UserID. These sessions come from several different tables and recordsets.
(On the login page, there isn't the option to create these session variables from different table - unless there is a way?)
When a user tries to access a restricted page without logging in, they are redirected to the login page, then on to the previously requested page. However, this bypasses the stats page and none of the extra session variables are created.
I've tried to create (on the login page) a Session Variable called 'accesscheck', based on $_GET['accesscheck'] if someone's tried to access a restricted page, but this still bypasses the stats page!
Any suggestions on the best way to accomplish this?
Many thanks
Chris
In the server behaviors panel, double click the Security Assist Authenticate user server behavior and uncheck the Go to previous URL option.
Sweens
Hi Jason
Thanks - I tried that, but it didn't make any difference (unless things are cached?) After making this change, do I only need to upload the login page, or are there security_assist pages that need uploading too?
Cheers
Chris
Sweens
Hi Jason
I've rebuilt the page and things now work as expected.
Cheers
Chris
ok, glad to hear it is working.
Sweens
Hi Jason
I spoke too soon - it worked once and hasn't done since! See pm
Chris
I added the following code to the login page to prevent it redirecting to the protected page:
if(isset($_SESSION['WASA_accesscheck'])) unset($_SESSION['WASA_accesscheck']);
if(isset($_SESSION['accesscheck'])) unset($_SESSION['accesscheck']);
Sweens
pm
pm
