Insert Summary isn't including Phone Number eCart 6.1.0
Thread begun 12/08/2014 7:10 am by troyd | Last modified 12/18/2014 10:05 am by Jason Byrnes | 6620 views | 18 replies |
troyd
I am troubleshooting an issue where the phone number entered into the checkout form isn't being stored in the db and isn't being saved as (WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Phone_Number'));
When looking at the insert summary behavior, I see that most of the columns use the function WA_coalesce(). It appears to be a ternary operator so that if Phone_Number_2 is empty, use Phone_Number. Is that correct?
(phone number binding for insert summary)
echo(WA_coalesce(array(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Phone_Number_2'),WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Phone_Number'))));
All of the other columns are being stored correctly using that function so I started looking elsewhere.
On the wa_receipt.php, confirm.php, confirm_cart.php & checkout_success.php pages I find for the phone number
echo(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Phone')); Shouldn't that be
echo(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Phone_Number'));?
Lastly, this checkout uses only one address form for shipping. No billing address. They fill that out at PayPal.
Thanks,
TroyD
troyd
Same subject second issue
On the same subject, it appears that the billing information at PayPal may be taking priority when inserting into the summary table.
I need to make sure that the address they fill in on the website's checkout page is the only information collected since that is the shipping address.
Can I just switch the order of the two in each WA_coalece() function in the insert behavior?
So this...
echo (WA_coalesce(array(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Address_1_2'),WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Address_1'))));
becomes this...
echo (WA_coalesce(array(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Address_1'),WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Address_1_2'))));
Will that work to keep what they entered on the site? Or can I just change it to echo(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Address_1')); and leave the billing address out of it since we don't have that form?
TroyD
what is the name of the phone number field on the checkout page? That is what should be used in the bindings. Same thing for the store order summary, use the bindings that correspond to the form element names on the checkout page.
troyd
Sorry Jason, I thought I included that.
It's Phone_Number which was generated by the wizard.
Here is the text input field for the phone number in it's entirety
<input id="Phone_Number" name="Phone_Number" type="text" value="<?php echo(WA_coalesce(array(WA_getSavedFormValue("CheckoutWizard_NewFromBlank_Default","Phone_Number"),(isset($_GET["invalid"])?ValidatedField("confirmcart","Phone_Number"):"")))); ?>" class="formTextfield_Large" tabindex="5" pattern="\(\d{3}\) \d{3}[\-]\d{4}" title="Please enter a 10 digit phone number" required onBlur="WAValidatePN(document.getElementById('CheckoutWizard_NewFromBlank_Default').Phone_Number,'',false,true,'x (xxx) xxx-xxxx',document.getElementById('CheckoutWizard_NewFromBlank_Default').Phone_Number,0,true);">
And the binding in the insert summary. It's the same name, right?
<?php echo (WA_coalesce(array(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Phone_Number_2'),WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Phone_Number')))); ?>
The only place I see it different, (and I will change it there) is the pages I mentioned where it uses just "Phone".
Thanks,
TroyD
you don't need to include the coalesce function, you can just echo the phone number:
<? echo(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Phone_Number')); ?>
troyd
Awesome. Thanks.
Then that answers my second question also.
Thanks,
TroyD
You're welcome.
TroyD
Jason,
This still isn't working to insert the phone number.
I made sure that every instance of echo(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Phone_Number')); had the correct name of "Phone_Number" in it since that is the exact name used for the phone number input.
It does show up in the session $_SESSION["WASF_WA_Payments"]["Phone_Number"] though. It's just strange that everything else name, address, city, etc. works but the phone number doesn't.
Could it have something to do with any other part of the pp_confirm page? Does PayPal change this somehow before returning to the success page?
This line for example $PPVals["Phone_Number"] = WA_PP_ECO_GetValue($WA_PP_ECO_GetResult, "PayerInfo->ContactPhone");
Should I be looking for something else?
The form field is called "Phone_Number".
The binding in the insert summary is
<?php echo (WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Phone_Number')); ?>
What am I missing? I'm sure it's an obvious one.
(See PM for attachment)
Thanks,
Troy
yes, this line:
will try to capture the phone number sent back from paypal.
it sounds like this is not being sent back properly, you can try commenting that line.
TroyD
Ok. Thanks. I'll report back.
TroyD
