MySQLi Update Record Server Behavior and File Upload
Thread begun 12/08/2014 3:47 am by john218811 | Last modified 12/08/2014 9:41 am by john218811 | 1294 views | 1 replies |
john218811
I can get the Update server behaviour to work fine except where a form has a file field to enable file upload (using the WA file upload extension).
And the file upload does work as expected. But after submitting the form without selecting an image file (when I do not need to update that) the image field is emptied and the image doesn't show.
john218811
Solved
Found the solution myself - under Column Bindings for the image field you need to set the Blank Value to Ignore.
