CSS form builder files missing?
Thread begun 12/06/2014 6:50 am by john70964 | Last modified 12/18/2014 9:46 am by Jason Byrnes | 5029 views | 11 replies |
john70964
Hello
I am using CSS Form Builder to create a simple contact form.
In my test I am getting at the end of the email the following items that are not required.
"Hidden Field:
SimpleContact submit: Contact me
Additional Notes: Lorem ipsum dolor sit amet, consectetur adipiscing elit. Donec eget tellus sed justo rhoncus posuere id sit amet arcu. Morbi pretium, enim faucibus facilisis hendrerit, elit. Morbi quis sodales ligula. Pellentesque elementum faucibus elementum. etc"
If I select the page Form then I can select CSS Form Edit Form
When I select this I get three options.
Form Function looks like it should give some help but when I select any of the links in Form Funtion I get File not Found.
I am attaching an image of this
Am I some files missing
and how can I remove the above fields please?
Many thanks
for any help you can give.
Regards
John
The form builder wizard should not be used for editing the email settings.
to edit the email body, you need to edit the email template file. see the following tutorial for details:
http://www.webassist.com/tutorials/Customize-form-elements-in-your-form-generated-emails
The form functions tab is really only relevant when Creating the for and should not be used on editing the form.
to edit the form functions, you would edit the server behaviors for either Universal Email or file upload by opening the server behaviors tab and double-clicking the corresponding server behavior.
john70964
Thanks Jason
The contact us email is now arriving OK
Under the message I have two fields that are not required:
Hidden Field
SimpleContact submit: Send
Can I remove these please?
the tutorial i linked to previously has details on how to accomplish this:
john70964
Thanks Jason
At the top of the email page, copy the line:
$remove[] = "y";
Paste a copy of the line under the it.
I am confused as to what is "the it"?
it should be:
$remove[] = "y";
Paste a copy of the line under it.
so that in the end you have the line repeated :
$remove[] = "y";
$remove[] = "y";
john70964
Many thanks for the help Jason
you're welcome.
john70964
Hi Jason,
I included the extra code as
$remove = array();
$remove[] = "";
$remove[] = "x";
$remove[] = "y";
$remove[] = "y";
But I am still getting Hidden Field and SimpleContact submit showing at the foot of the page.
as per
Form Submitted: 12-14-2014 | 9:32 PM CET
Full Name: Mr test
Email Address: john@net100.co.uk
Comments: This is a test message only
Hidden Field:
SimpleContact submit: Send.
Any ideas please?
John
you didn't follow the rest of the steps which are to inspect the form element you don't want to have appear in the email, it looks like in the case the name is:
Hidden_Field
and
SimpleContact_submit
and then to edit the line that was a added:
$remove[] = "y";
and replace y with the form field name, in you case, you have 2 form files, so you need to do this twice:
$remove[] = "Hidden_Field";
$remove[] = "SimpleContact_submit";
