DataAssist: Insert single record -> General -> database -> table : ***No Table Found
Thread begun 12/05/2014 11:55 pm by story.book.904 | Last modified 4/20/2015 9:58 am by Ray Borduin | 7681 views | 22 replies |
story.book.904
Following the tutorial video, I have reached the part where I was supposed to edit the "Insert Record(user)" under Server Behavior. However, I was unable to comply because no table is found and therefore the list under bindings is empty. When I go to phpMyadmin, under the database I was using for the site, everything was there as per shown in the tutorial video, except they were only contained in the Columns tab. Whereas the table itself under the Users tab gave this message:
MySQL returned an empty result set (i.e. zero rows). (Query took 0.0010 seconds.)
Having followed the tutorial to the teeth and redone it at least 6 times (due to other problems arising), I have no idea which part I did wrong to cause this. Please advise thanks.
What tutorial is it you are following? I can't really help find what steps you may have gone wrong on without knowing what tutorial you are using.
It sounds like there may be an issue with either the site settings for the testing server, or the database connection. are you using a local testing server? is the connection properly set to connect to the database. Is the testing server running?
story book
Oh sorry I didn't update this. The issue seemed to have solved itself eventually after I deleted everything and started from scratch, so maybe I did something wrong in between back then.
ok, glad to hear it is working.
mmichals347710
Hi Jason,
I'm having the same problem. It pertains to the web development tutorial on Double Opt In Registration.
When I reach the "Add the string to the database" section and double click the "Insert Record (users)" server behavior, the DataAssist: Insert Single Record dialog box appears but I cannot select any database table from either my local testing server or the remote server.
How can I manually update the PHP code to move past this step?
The "Undefined Error Hs Occurred" error means that there is a problem with the Site settings for connecting to the Testing server.
Double check the site settings and make sure that the settings for the connecting to the testing server are correct.
If you are using an FTP connection to use the remote server as the testing server, you may need to enter a root directory if the connection does not go directly to the site root.
and make sure that the WebURL is the correct Web Address to connect to the server.
mmichals347710
Verification Email Not Being Sent + Registration.php not registering new users
Thanks Jason, I got it working and finished the Double Opt In Registration development tutorial. But I have a new problem.
Do you have any idea why verification emails are not being sent? Also, the registration.php page is populating all of the "users" table fields with "NULL" with the exception being the randomString and emailVerified fields. Should I delete all the files and start over similar to what story.book.904 had done?
"Do you have any idea why verification emails are not being sent?"
that can be for a number of reasons.
First, are you testing locally? if so that won't work for the emails, unless you have a SMTP server installed which is not a part of most local testing setups. you will need to test on the live server.
next thing to look at is the Insert behavior, is that set to redirect after the record is inserted? if so, that will prevent the email from sending. the redirect should be done in the email behavior.
if it's still not sending the email:
Who is your host?
Depending on your host, you may need to set certain options in Universal Email.
Some hosts will work if you leave the SMTP Server setting on the Email Server Tab blank, others will require that you enter the SMTP server address.
Some will work using the standard Mail protocol, other will require that you use the Pear Mail for SMTP, some using Pear mail will require authentication.
Some hosts may require that the from address being used be a valid email address for your domain. Some may require that the option to include the from Email address be passed as an extra parameter.
To be successful with Universal Email, you will need to know the requirements of your host for sending an email using a PHP script.
Also, double check your Spam folder, it is possible that the email is being trapped as spam.
As for only saving the random string, double check the insert behavior again on the registration page and make sure the columns are bound to the corresponding form elements on the registration page.
mmichals347710
Who is your host?
Hi Jason,
I'm running the site off the remote server - I'm using Dreamhost.com. I think they were suggested by WebAssist before. Do you have specific SMTP setup instructions for Dreamhost? Here's their discussion forum: https://discussion.dreamhost.com/search.php
Not sure what you mean by whether the insert behavior is set to redirect after the record is inserted?
I already checked the spam folder and the email wasn't there. I did receive one verification email from the three times I tried which is strange.
The first thing to check is the insert behavior.
open the insert record behavior and makes sure that it is not set to predict to another page. of it is, remove the redirect.
once you have validated that, we will look at the Dreamiest email server settings if it still does not work.
