Reset results after search; results nav buttons not working
Thread begun 12/05/2014 11:20 am by DeanCollins | Last modified 12/08/2014 9:47 am by Jason Byrnes | 3855 views | 7 replies |
DeanCollins
Data Bridge 1.2.1; Windows 8.1; Dreamweaver CC 2014
1. After a search, how do I get the full results set back? Refreshing the page doesn't do it. Seems that only by using the back button can I return.
2. There are 51 records in the results, but only the first 20 display. Clicking the next button results in a "no results found" message.
3. Oh, and one other thing: Do I have to manually insert a "back to results" link on the insert, update pages? Seems like this would be something that would somehow be included.
1) See this page for details on resetting the search results:
http://www.webassist.com/forums/showpost.php?p=93270&postcount=2
2) I'll need to troubleshoot directly, see the private message section.
3) Yes, you would need to add links to go back to the results page.
DeanCollins
Will do.
I'm not seeing any results at all on that page?
DeanCollins
Sorry! I made a change I shouldn't have. The results are back now.
the following code block on the results page was out of place:
$queryString_WADAjob_descriptions = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_WADAjob_descriptions") == false &&
stristr($param, "totalRows_WADAjob_descriptions") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_WADAjob_descriptions = "&" . htmlentities(implode("&", $newParams));
$queryString_WADAjob_descriptions = sprintf("&totalRows_WADAjob_descriptions=%d%s", $totalRows_WADAjob_descriptions, $queryString_WADAjob_descriptions);
i moved it to be before the doctype tag to fix the issue.
DeanCollins
Thanks!
you're welcome.
