Search produces warning: Warning: virtual(): Unable to include '/webassist/form_validations/wavt_scripts_php.php' - request execution failed in /
Thread begun 12/04/2014 7:56 pm by beaded | Last modified 12/08/2014 9:48 am by Jason Byrnes | 4330 views | 5 replies |
beaded
A basic search now produces this: Warning: virtual(): Unable to include '/webassist/form_validations/wavt_scripts_php.php' - request execution failed in /Applications/MAMP/htdocs/LisaCakeTest/products_results.php on line 0
Where have I fumbled. products_search page attached
The error is happy ning because DW is using the virtual function for attaching include files on the results page instead of using the require_once function.
In your site definition, there is a setting for "Create Links Relative To", Normally DW Uses Virtual for include files when this is set to Site. it should be set to document instead so DW Will use the require_once function.
beaded
T H A N K S ! ! !
you're welcome.
beaded
Oh, hmmm…. I tried this and I got the same message. Should I also have re-created the Data Assist pages after I made the change? Thanks.
YEs, you would need to recreate the [ages to regenerate the code.
