Changing Div Width
Thread begun 12/04/2014 12:40 pm by john70964 | Last modified 12/05/2014 10:06 am by Jason Byrnes | 2511 views | 3 replies |
john70964
Changing Div Width
Hello
In the attached image I have a div containing the word Required
I want to bring that to the left about 100 pixels.
How can I do this please?
Thank you
John
probably adding a margin-right to the containing div would move it, I would need a link where i can see the page to give more specifics.
john70964
Thanks Jason
Regretfully I do not have this site live at the moment so I have zipped a text file and hope that you may be able to advise from that.
I could use several *  's but thought there must be a better way?
John
I can't troubleshoot from the page code, it does not include the css.
When the page is uploaded to a server for testing i will be able to troubleshoot the css.
you could also troubleshoot this on your end using Fire Fox and the Fire Bug extension. Fire Bug allows you to select section of the page and see and edit the css for that section. using Fire Bug, you can find the CSS for the required section and try adding the right margin to it.
see this page for details on using Fire Bug:
http://www.webassist.com/tutorials/Using-Firebug
