Working in MySQL, but data bridge doesn't recognize that, and instead gives error "your php server doesn't have MySQLi module
Thread begun 12/04/2014 11:23 am by mediawerx | Last modified 12/04/2014 11:57 am by Jason Byrnes | 1886 views | 4 replies |
mediawerx
have done multiple installs/uninstalls of databridge zxp extension, and have removed any old webassist extensions in CC2014.1, but data bridge insists on looking for a MySQLi module on my server. My original data connections are straight to the server (worked perfectly in old data assist) but they now read as having no tables in data bridge. The MySQLi problem is also evident on my CS6 as well after I installed the mxp in that version
This will happen if eCart 6 or the MySQLi extensions are installed.
you should contact the host to have them enable the MySQLi library in your php server.
mediawerx
I'll try that and get back to you...I doubt they'll do it right away, but I'll let you know when/if they do it....and what my result was here
mediawerx
...oops, by the way
I don't have eCart on my CC2014.1....but I do have it on my CS6
it should be fairly simple for them to edit the php.ini file and enable the MySQLi library.
