When using your Mysqli Server Behaviors, do i need to prepare the code prior to insertion to avoid SQL Inection issues?
Thread begun 12/03/2014 3:53 pm by han hau lin | Last modified 12/04/2014 10:03 am by Jason Byrnes | 2446 views | 4 replies |
han hau lin
make sure that the correct Data Type in the insert behavior is selected for each column, for example use a number data type for numeric columns, the text data type for text columns, etc, and there should not a problem with SQL Injections.
han hau lin
sweet as! thanx
James
han hau lin
one thing i noticed, that's a wee bit annoying is the insert behavior does not auto populate the data type for TINYTEXT. it comes up as checkbox?
I will log this as a bug in our system.
