The files from the _mmServerScripts folder are for the server model PHP-MySQL
Thread begun 12/03/2014 10:52 am by Nathon Jones Web Design | Last modified 12/03/2014 3:50 pm by Jason Byrnes | 4626 views | 3 replies |
Getting this error when trying to open or create any recordsets on a website that has been working fine up to now:
The files from the _mmServerScripts folder are for the server model PHP-MySQL. You try to connect to a database using a different server model .
Please remove this folder outside the Dreamweaver environment on both local and testing machines and try again.
We haven't changed anything!
Hope you can help.
NJ
In the site definition, what is the URL address for the testing server?
I have seen this happen before if there was an hatches rule in effect on the server that forced the address to be different from the testing server address,
for example, if the testing server address is:
http://mydomain.com
and you had an hatches rule forcing that to the www address:
http://www.mydomain.com
that error can happen.
if you have an htaccess rule in feet on your site to force a URL, make sure that is what you use in the site definition.
Ah...this is because we're forcing the URL by making the change in the htaccess file to force https!
Groan!
I've changed the URL to https in the site definition section and all is well.
Thank you.
NJ
you're welcome.
