Displaying info from more than one table
Thread begun 12/01/2014 6:09 am by Mags | Last modified 12/02/2014 10:18 am by Jason Byrnes | 3150 views | 7 replies |
Mags
Having a nightmare trying to get some info to display correctly. I have 3 tables: users, accountants and clients. The common column in all of them is called JFBMicroID and contains a reference number in the format ABCD1234EFGH. It's basically a one to many to many relationship between the three tables: each user can have multiple accountants, and each accountant can have multiple clients.
I have a page set up in the users' members' area (created using SecurityAssist) where I want users to be able to view a list of all their accountants (identified by JFBMicroID), and also display the total number of clients that each accountant has, like this:
Firm Name Contact Name Email Address No. of Clients registered
Test Firm 1 Joe Bloggs test@firm1.com 4
Test Firm 2 John Doe test@firm2.com 8
I have a session variable on this page called JFBMicroID. The variable does work because elsewhere on the page I have a line that says:
Below is a list of all those who have registered so far using your Unique Registration Number: ABCD1234EFGH
However, the variable is not being picked up in the recordset. Instead it's displaying a list of all accountants regardless of their JFBMicroID. Actually, not all - 42 out of 115, not sure why! I'm also not sure how I would display the total number of clients next to each accountant.
The recordset currently looks like this:
$paramSession_rsAccountants = "-1";
if (isset($_SESSION['JFBMicroID'])) {
$paramSession_rsAccountants = $_SESSION['JFBMicroID'];
mysql_select_db($database_new_greenroom, $new_greenroom);
$query_rsAccountants = sprintf("SELECT * FROM accountants JOIN clients ON accountants.AccountantID = clients.AccountantID WHERE accountants.JFBMicroID = %s GROUP BY clients.AccountantID ORDER BY accountants.FirmName DESC", GetSQLValueString($paramSession_rsAccountants, "int"));
$rsAccountants = mysql_query($query_rsAccountants, $new_greenroom) or die(mysql_error());
$row_rsAccountants = mysql_fetch_assoc($rsAccountants);
$totalRows_rsAccountants = mysql_num_rows($rsAccountants);
In the recordset, you have the data type for the paramSession variable set to integer, but it needs to be set to text. the value:
ABCD1234EFGH
is a string, so cannot be treated as an integer. using an integer data type is causing:
ABCD1234EFGH
to ne converted to:
1234
Mags
Fantastic Jason, that's sorted out the session variable being recognised. However, I'm still having a problem displaying the correct info, and it's obviously the way I have the recordset set up, i.e. wrongly! I need to display all the accountants whether or not they have any clients - at the moment it's only displaying those accountants who have clients attached to them. I also don't know how to display the total number of clients that belong to each accountant - at the moment I have 3 accountants:
Accountant 1 has 4 clients
Accountant 2 has 2 clients
Accountant 3 has no clients
I need them to display on the page as follows:
Accountant 1 4
Accountant 2 2
Accountant 3 0
change the join to a LEFT JOIN
see the following page for details on the different join types:
http://blog.codinghorror.com/a-visual-explanation-of-sql-joins/
to get the number of records use the count function. see this page for more info:
http://www.w3schools.com/sql/sql_func_count.asp
you may also need to use a GROUP BY clause:
http://www.w3schools.com/sql/sql_groupby.asp
Mags
Hi Jason
Thanks for the pointers - I've got it working using the following:
and the recordset:
$query_rsAccountants = sprintf("SELECT *, COUNT(*)
FROM clients RIGHT OUTER JOIN accountants ON clients.AccountantID = accountants.AccountantID WHERE accountants.JFBMicroID = %s GROUP BY accountants.AccountantID, clients.AccountantID ORDER BY accountants.FirmName ASC",
It now displays the correct total number of clients for each accountant - except where there are no clients. If an accountant has no client, it's displaying 1 instead of 0. Any idea why this might be?
because you counting all, which includes the accountant record, not counting the client IDs. for the count use:
COUNT(accountants.AccountantID)
Mags
Thanks Jason, it gives me the correct result if I count on clients.AccountantID - many thanks for your help!
you're welcome.
