security assist Athenticate user
Thread begun 11/30/2014 11:26 am by bbgd | Last modified 12/01/2014 12:46 pm by Jason Byrnes | 1182 views | 1 replies |
bbgd
I have had this problem before. i found a thread that was similar to mine and piggybacked off of it. Jason came back with the answer but didn't understand it. He then ended up calling and helping me. I have lost the thread to that problem and had to restart the whole thing again. I am now stuck in the same spot.
In the SecurityAssist Authenticate User dialog box on the Database tab I have username and passowd columns. I believe the value is where I am having problems. When I click on the lightning bolt I can pick from Sessions, Cookie or Form. No matter what I pick. I get redirected back to my denied.php page.
Under the Session Value tab I have username and password. I can't find any tutorials or info on this dialog box.
I did http://www.webassist.com/tutorials/User-level-authentication-with-SecurityAssist and still don't understand.
I should have added the contents of the general tab. Trigger is "any form post". Redirect has both check boxes checked and a page to go to if successful and on that if it fails.
Now, under Access Page Manager. The pages I want restricted have the Rule "logged in to login_form" applied to each.
In the dialog box I have the name of the rule. and under Conditions, I have
Allowed if <?php echo ((isset($_POST["username"]))?$_POST["username"]:""); ?> = <?php echo $_SESSION['username']; ?>. Same for password.
Last but not least. I want who ever click on a restricted page to go to the login first. Right now it goes straight to the denied.php page.
In the authenticate user behavior, on the Database tab, you should selecting the Username and password columns and binding the, to the username and password form elements.
On the session tab, you should be saving the ID column as a session, you can save other columns if you wish, but the ID column is the only one that is really needed.
in the access rule, it should be configured as:
Allow if
Variable: click the lightning bolt and select the Used ID Session
<> (Not Equals
Comparison: leave this blank.
