Hi I have a database search results page that I would like to paginate but as it moves from the first page to the next page it loses the value of the search term. s <?php $search_rs = new WA_MySQLi_RS("search_rs",$connection,10); $search_rs->setQue
Thread begun 11/29/2014 11:10 am by Andrew | Last modified 12/02/2014 2:56 pm by Jason Byrnes | 4826 views | 11 replies |
Andrew
Hi I have a database search results page that I would like to paginate but as it moves from the first page to the next page it loses the value of the search term. s <?php $search_rs = new WA_MySQLi_RS("search_rs",$connection,10); $search_rs->setQuery("SE
Hi
ie
The recordset is
$search_rs->setQuery("SELECT * FROM items WHERE items.itemTitle LIKE '%".$_POST['search']."%' ORDER BY items.itemTitle ASC");
$search_rs->execute();
with 'search' being POSTed from another page.
This successfully produces a list of 10 results using ...
while(!$search_rs->atEnd()) {
<tr>
<td><?php echo($search_rs->getColumnVal("itemNo")); ?></td>
<td><?php echo($search_rs->getColumnVal("itemTitle")); ?></div></td>
</tr>
$search_rs->moveNext();
$search_rs->moveFirst();
Adding and clicking the link
<a href="<?php echo $search_rs->getNextPageLink(); ?>">Next</a>
before the results listing gives "undefined index" for the query ie it has lost the 'search' value.
Hope that this makes sense.
Would be grateful for any suggestions to solve this.
Andrew
change the next link:
<a href="<?php echo $search_rs->getNextPageLink(); ?><?php echo(isset($_POST['search'])?"&". $_POST['search']:""); ?>">Next</a>
then add the following at line 1:
if(isset($_GET['search'])) {
$_POST['search'] = $_GET['search'];
Andrew
Hi
I've done as you said - copied and pasted.
It lists the first ten results correctly and then again on page two loses the value of the variable and lists the entire database.
Notice: Undefined index: search in C:\wamp_php5_5\www\sheffieldarchives\database_admin\admin_search_library_results.php on line 9
where line 9 is
(Point of clarification - I've no knowledge of php - I've added
immediately above the pagination code. I assume that is what you meant.
Thanks in anticipation
Andrew
no, this code:
needs to go at line 1, not above the pagination.
Andrew
That is where I originally placed it - but then I thought about it too much!
I have put it at Line 1 - and it has made no difference.
please send a link to your site where i can see the problem occur and ftp login details so I can access the site files directly to troubleshoot.
Andrew
See below
i am not able to reproduce.
I go to the search page, enter test and hit the submit button, no error.
on clicking the next button, i still don't see an error.
Andrew
See below
I see, I was looking for the error you reported, not paying attention to the results.
Sorry, the code for the next link:
should be:
<a href="<?php echo $search_rs->getNextPageLink(); ?><?php echo(isset($_POST['search'])?"&search=". $_POST['search']:""); ?>">Next</a>
