CMS giving errors wiol not open: Warning: mysql_fetch_assoc() expects parameter 1 to be resource, boolean given in ...
Thread begun 11/28/2014 6:46 pm by balexander389215 | Last modified 1/08/2019 2:22 pm by anonymous | 253803 views | 4 replies |
balexander389215
I set up CMS on my testing server and all is well so I uploaded all the files to the live server. When I try to go to admin_cms I get the following:
Warning: mysql_fetch_assoc() expects parameter 1 to be resource, boolean given in /home3/cygnet/public_html/WA_Globals/WA_Globals.php on line 41
Warning: mysql_free_result() expects parameter 1 to be resource, boolean given in /home3/cygnet/public_html/WA_Globals/WA_Globals.php on line 67
Warning: Cannot modify header information - headers already sent by (output started at /home3/cygnet/public_html/WA_Globals/WA_Globals.php:41) in /home3/cygnet/public_html/webassist/security_assist/helper_php.php on line 65
In addition to that cm captcha has disappeared. On my test server, on the files using captcha it still appears properly however on the uploaded pages the captcha element is no longer there.
Help!
When you upload Power CMS to the server, you will need to edit the connection file to use the proper credentials for connecting to the remote database.
You will also need to export the database from your local testing server and import it to the remote server using PHPMyAdmin.
balexander389215
Thank you Jason,
Yes I did all that, what I didn't realize is that the files all got transferred into the wrong database. I've sorted that out and everything works fine now, thanks.
Glad to hear it is working.
