Multiple selections not showing in email
Thread began 11/28/2014 4:05 pm by Sylvia | Last modified 12/03/2014 1:06 pm by Jason Byrnes | 1239 views | 5 replies |
Sylvia
I have two multiple select boxes in a form and am unable to get the results to post to my custom UE (they are fine in the default email).
The form page has the following implode code at line 1:
if($_SERVER["REQUEST_METHOD"] == "POST") {
foreach($_POST as $key => $val) {
if(is_array($_POST[$key])) $_POST[$key] = implode(", ", $_POST[$key]);
and the bindings in the email page have this implode code
<?php echo((isset($_POST["services"]))?implode(",",$_POST["services"]):"") ?>
so I am at a bit of of loss - your help would be much appreciated. Files attached.
Sylvia
code looks right.
Sylvia
See pm
using implode in the email body was causing a conflict because impede was already at line 1 of the form page.
i changed the bidding for the services to use the standard echo instead of trying to impede it:
<?php echo(isset($_POST["services"])?$_POST["services"]:""); ?>
Sylvia
Great, thanks Jason - I have noted for future. Appreciate your help.
you're welcome.
