Error on install
Thread begun 11/26/2014 12:14 pm by Eric Goodman | Last modified 12/02/2014 9:57 am by Jason Byrnes | 5160 views | 17 replies |
Eric Goodman
Error on install
I successfully connected to database, added the CMS to 4 different PHP pages. When I go to the URL+admin_cms I get the following: 404 (Page Not Found) Error
Also, If I try to go to any of the actual web pages I get:
Warning: require_once(Connections/PowerCMSConnection.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/33/12382133/html/mobile/qr_aa.php on line 1
Fatal error: require_once() [function.require]: Failed opening required 'Connections/PowerCMSConnection.php' (include_path='.:/usr/local/php5_3/lib/php') in /home/content/33/12382133/html/mobile/qr_aa.php on line 1
Eric Goodman
See PM
See PM
could be a conflict with an hataccess rule you have defined?
Eric Goodman
Error on install
See PM
Eric Goodman
error on install
I also notice if I go to the /admin_cms page and enter the info it then comes up with a 404 error.
The FTP info provided is not working
Eric Goodman
See PM
See PM
See PM
Eric Goodman
Files
They are in a folder called mobile and draw upon the CSS and images that are in the mobile folder. I could have sworn that I was able to use the Power CMS with php files inside other folders...
sorry, i missed that you motioned to look in the subfolder.
when applying CMS to files in a subfolder, the path to the connection and WA_CMS/WA_CMS.php files need to be modified to move down to the root:
for example:
<?php require_once('../Connections/PowerCMSConnection.php'); ?>
<?php require_once("../WA_CMS/WA_CMS.php"); ?>
also, it doesn't look like the connection file was uploaded, there is no connection folder at the root.
like i said, files cannot be found on the server if they are not uploaded.
