How to remove "LIMIT 1"
Thread begun 11/26/2014 4:57 am by randyrie405335 | Last modified 11/26/2014 9:23 am by Jason Byrnes | 1856 views | 4 replies |
randyrie405335
MySQLi recordset builder is inserting by default a "LIMIT 1" SQL parameter. I cannot remove it via the builder (GUI) and if I remove the ",1" from within in the code, the recordset no longer displays in the Server Behavior panel. Is this a default setting I must defeat? If so, how?
Displayed in the code:
$rsAbstracts = new WA_MySQLi_RS("rsAbstracts",$icmids,1);
$rsAbstracts->setQuery("SELECT abstracts.* FROM abstracts");
$rsAbstracts->execute();
$rsAuthors = new WA_MySQLi_RS("rsAuthors",$icmids,1);
$rsAuthors->setQuery("SELECT DISTINCT Author FROM abstracts ORDER BY Author ASC ");
$rsAuthors->execute();
See "LIMIT 1" displayed in the attached screen capture of the GUI.
Jamie
Hey Randi
If you want to return all records from a recordset you need to replace the 1 with a 0 (if you want to return a specific number of records, say 5, just replace the 1 with 5 or whatever number you want)
from this
to this
$rsAuthors = new WA_MySQLi_RS("rsAuthors",$icmids,0);
randyrie405335
Thanks!
Yup - that worked, Jamie.
Wonder why MySQLi sets a " LIMIT" in the SQL by default and if there is a way to disable this?
Jamie
Glad it worked!
I believe it just defaults to 1 but you are able to either manually change as above or use the mysqli repeat region function to select the number you want to set it to - I dont know if the default is changeable.
Jamie
The default is not changeable.
It defaults to 1 to ensure that overlarge data sets are not created that could overload the servers memory and other resources.
The thinking is that if you are not using a repeat region to return more rows, then really you will most likely only use the first record in the result.
In the recordset you can set the limit to 0 if you don't want to add a repeat.
