Facebook Conversion Code
Thread began 11/25/2014 1:45 am by Nathon Jones Web Design | Last modified 11/25/2014 12:54 pm by Jason Byrnes | 2364 views | 3 replies |
Client has asked us to install Facebook conversion code on their checkout success pages. It looks like this:
<!-- Facebook Conversion Code for Checkout success customers -->
<script>(function() {
var _fbq = window._fbq || (window._fbq = []);
if (!_fbq.loaded) {
var fbds = document.createElement('script');
fbds.async = true;
fbds.src = '//connect.facebook.net/en_US/fbds.js';
var s = document.getElementsByTagName('script')[0];
s.parentNode.insertBefore(fbds, s);
_fbq.loaded = true;
window._fbq = window._fbq || [];
window._fbq.push(['track', '6018866625924', {'value':'0.00','currency':'GBP'}]);
</script>
<noscript><img height="1" width="1" alt="" style="display:none" src="https://www.facebook.com/tr?ev=6018866625924&amp;cd[value]=0.00&amp;cd[currency]=GBP&amp;noscript=1" /></noscript>
I've not received any instruction, apart from the code above, so I'm assuming it slots into the head section of our checkout_success.php page - please correct me if I'm wrong there - but how do I replace the 0.00 value with that of the eCart Grand Total?
It occurs twice...once in the first script section, and then in the URL that's referenced in the second script section.
Thank you.
NJ
look like your referring to the face book conversion pixel, see this page for more details:
https://www.facebook.com/help/435189689870514/
according to that page, the code goes between the <head> and </head> tags
to write the cart grand total use:
<?php echo $cartName->GrandTotal(); ?>
where cartName is the name of the eCart object
so as an example, for this code:
you would replace 0.00 with <?php echo $cartName->GrandTotal(); ?>:
window._fbq.push(['track', '6018866625924', {'value':'<?php echo $cartName->GrandTotal(); ?>','currency':'GBP'}]);
Thank you Jason.
And would the URL convert from this:
...to this?:
https://www.facebook.com/tr?ev=6018866625924&amp;cd[value]=<?php echo $cartName->GrandTotal(); ?>&amp;cd[currency]=GBP&amp;noscript=1
Thank you.
NJ
yes, that looks correct.
