Multiple Update not working with Select
Thread begun 11/24/2014 9:17 pm by KTay36841385 | Last modified 11/26/2014 10:11 am by Jason Byrnes | 2544 views | 4 replies |
KTay36841385
I have been attempting to use Multiple Update and Multiple Insert unsuccessfully. Leaving Multiple Insert aside for now, the Data Assist Multiple Update appears to be impacted by a Select in the first column of the repeat region (fails to post to data base).
Here is my sequence:
1) I created the php page from a template from a WA CSS Sculpt.
2) I created the form and populated with a table to format page.
3) I used the deprecated Recordset behavior in Dreamweaver and the Dreamweaver Repeat Region for same.
4) I have a Select in the first and second columns of the Repeat Region.
5) I added the Multiple Update from Data Assist—no database post.
I have saved the resulting code as ym_mb_edit.php (see attached).
On a whim, I tried a different approach—I eliminated the Select in the first column and dropped in the text from the recordset. All other behaviors were as above. As far as I can tell, there are no differences between the first page and this second one (ym_mb_edit2.php) other than the replacement of the Select with text in the Repeat Region. This second version posts, no problems.
Is there some reason the Select (NOT a multi-Select) should be causing the code to fail?
I am experiencing a similar issue with the Multiple Insert—I have coded up per the tutorial, but can’t get it to post. I have NOT created a second file from scratch with text in the first column of the repeat region, but am suspicious that the issues I am having on multiple posts (insert or update) may be the same.
Thanks.
KTay36841385
Jason:
I will forward all requested information in a couple our hours when I get back to my development machine.
Thanks.
KTay36841385
Jason:
See private area.
Thanks.
2 problems:
1) your submit button had a space in the name. spaces are not valid in form element names, i updated the submit button to remove the space from the name.
2) where you have the redirect set to go to the same page, the update code needed to be moved above the recordsets so you could see the changes without having to refresh the page.
