Error on Update Cart
Thread begun 11/24/2014 1:15 pm by bill173836 | Last modified 11/25/2014 12:38 pm by Jason Byrnes | 5390 views | 7 replies |
bill173836
I'm getting this error when ever I click the Update Cart button or Apply Promo Code button.
Fatal error: Call to undefined method siteCart_Definition::CartUpdate() in ...sitestuff.../shopping-cart.php on line 159
The Continue Shopping and Clear Cart buttons work fine.
I've attached the shopping cart file and you can see for your self by going to http://www.awinninglook.info/store.php to add a test item. Thanks.
the update code is duplicated at lines 145 - 166:
// WA eCart Update
if (isset($_POST["siteCart_Update_100"]) || isset($_POST["siteCart_Update_100_x"])) {
$siteCart->UpdateCart();
$Redirect_redirStr="";
if ($Redirect_redirStr != "") {
$siteCart->redirStr = $Redirect_redirStr;
$siteCart->cartAction = "Update";
// WA eCart Update
$siteCart->CartUpdate();
remove the second instance at lines 156 - 166.
bill173836
I took the extra code out but I still get the same type of error it's just on line 148 now.
bill173836
Here you go. Thanks.
Looks like the cart for this page was created using eCart 5, but the display manager has been created using eCart 6.
you need to update the eCart object.
Open the eCart object panel, select to edit the siteCart object, then click ok to have the eCart object code regenerated. make sure to up;load the new eCart object file to the server.
bill173836
Thanks, that seemed to work. I did have to add the second Update code back in or it didn't do anything when I clicked the Update or Apply Code buttons.
glad to hear it is working.
