Search function
Thread begun 11/21/2014 9:24 am by russb335115 | Last modified 12/04/2014 11:26 am by Jason Byrnes | 3148 views | 7 replies |
russb335115
Search function
In one of the search functions that I create with premier support I'm getting this error:
Fatal error: Out of memory (allocated 61603840) (tried to allocate 12052 bytes) in /homepages/19/d403739231/htdocs/antronix/webassist/caching/CachedResize_Image.php on line 106
This only pops up with one specific search query. Is it because the image that was loaded into the server for this product is to large?
try adding the following code at line 1 of the results page:
ini_set("memory_limit", "256M")
russb335115
That didn't help I'm still getting the same error.
russb335115
Still having an issue with this can you help? See PM for login info:
This only happens with some images right? The images that are having the problem are to large to be resized.
In most cases, setting the memory limit using ini_set should give the script enough memory to process larger images, but in your server configuration this is not working, you will need to work with the host to increase the available emory for your site, or if they won't increase that, use smaller images to begin with.
russb335115
Yea, that's what I thought. I will have to have them use smaller images.
Thanks for your help.
you're welcome.
