syntax error, unexpected ')' when using DataAssist Sort
Thread begun 11/20/2014 5:32 am by sabastian130416448 | Last modified 11/24/2014 11:13 am by Jason Byrnes | 4255 views | 7 replies |
sabastian130416448
Hi guys.
I am trying to create a function where my customers can sort the results page according to how they want the products displayed.
Now I followed the tutorial all the way through but when I finish I keep getting this error no matter what I do (Parse error: syntax error, unexpected ')' in C:\xampp\htdocs\henkorsite\shopping-pages-template1.php on line 156)
I have attached the page and hope that you can help me out.
156 is the query line, change:
$query_RcrdsetHenkor = sprintf("SELECT * FROM product_range WHERE name_tb LIKE '%tiger nut", );
$query_RcrdsetHenkor = "SELECT * FROM product_range WHERE name_tb LIKE '%tiger nut'";
sabastian130416448
Now I get these three errors.
Notice: Undefined variable: WADA_Sort_1 in C:\xampp\htdocs\henkorsite\shopping-pages-template1.php on line 157
Notice: Trying to get property of non-object in C:\xampp\htdocs\WADbSearch\HelperPHP.php on line 381
Notice: Trying to get property of non-object in C:\xampp\htdocs\WADbSearch\HelperPHP.php on line 395
sabastian130416448
See private message.
the data assist sort code block:
//WA DataAssist Sort (Copyright 2007, WebAssist.com)
//Recordset: RcrdsetHenkor;
$WADA_Sort_1 = new WADA_SortObject();
$WADA_Sort_1->DefaultSort = "";
$WADA_Sort_1->ColumnList = "".((isset($_GET["sort"]))?$_GET["sort"]:"") ."";
$WADA_Sort_1->SortOrderList = "Ascending";
$WADA_Sort_1->ToggleOn = true;
if ((((isset($_GET["sort"]))?$_GET["sort"]:"") != "")) {
$WADA_Sort_1->SetToClause = $WADA_Sort_1->getDefaultSetToClause();
if ($WADA_Sort_1->ToggleOn && isset($_SESSION["WADA_OrderClause_shoppingpagestemplate1"])) {
$WADA_Sort_1->ToggleClause = $_SESSION["WADA_OrderClause_shoppingpagestemplate1"];
else if (isset($_SESSION["WADA_OrderClause_shoppingpagestemplate1"])) {
$WADA_Sort_1->SetToClause = $_SESSION["WADA_OrderClause_shoppingpagestemplate1"];
$WADA_Sort_1->initialize();
$_SESSION["WADA_OrderClause_shoppingpagestemplate1"] = $WADA_Sort_1->SetToClause;
was in the wrong location, i moved it to line 124 to fix the error
sabastian130416448
Ok I moved the coding on my testing server to line 124 but now I get no results?
that's a problem with the recordset query.
your where claus:
is looking for the string "tiger nut" at the end of the name it will only return a result if the the name ends with "tiger nut". your not getting any results because you don't have any products whose name ends with "tiger nut"
if I change that to:
WHERE name_tb LIKE '%tiger nut%'
it is looking for the string "tiger nut" anywhere in the name, and returns a result.
be careful with the wild card characters when doing a like query. depending on how you use the wild card, you create a 'Begins With', 'Ends With', Or 'Contains' condition:
Begins with 'foo'
SELECT * FROM tableName WHERE columnName LIKE 'foo%'
Contains 'foo'
SELECT * FROM tableName WHERE columnName LIKE %foo%'
Ends with 'foo'
SELECT * FROM tableName WHERE columnName LIKE '%foo'
