File Permissions Power CMS
Thread begun 11/19/2014 11:10 am by jo271221 | Last modified 12/01/2014 8:48 am by Jason Byrnes | 4479 views | 9 replies |
jo271221
I am at the point where I need to allow permissions. Do I allow 777 to the entire public html and then change back or what is best?
I attempted to allow 777 to the directories I guessed would need it and still get the error. Is just certain directories or ?
http://www.baltezoreperformancehorses.com/install_cms/diagnostic.php
File Permissions
Files and directories cannot be created. Verify the ../ directory has write permissions on your server.
the directory that Power CMS is uploaded to needs to have full write permissions, if you upload it to the site root, then the site root needs write permissions, if you upload it to a subdirectrlory, then the subdirectory needs the write permissions.
Looks like you have it uploaded at the site root.
jo271221
What should the numeric value be for files? for directories? I used 776 and ....
I set the permissions to 776 for files and directories.
Errors
You don't have permission to access /Templates/inside_template.dwt.php on this server.
http://baltezoreperformancehorses.com/ - Style sheet is not found or something
You don't have permission to access /admin_cms on this server.
normally, 755 for folders and 644 for files is sufficient.
jo271221
Info requested is in PM
For some reason, the server will inly allow the files to be accessed if the permission is set to allow read write for the public, either 767 to 777
it should be able to work with 755 for folders and 644 for files. you should contact the host to determine why you have to give such elevated permissions to run access files and folders on the site, it should not require 777 like it is now.
jo271221
I have submitted a ticket to the hosting company. Did you do something to make the style sheets and images link back up? The page was not displaying correctly and it is now. Thank You.
yes, i set the permissions for those folders to 767, but it should not need that broad a permissions to be able to work.
jo271221
What is the numeric value and also name that I should set the permissions on my directories to?
What is the numeric value and name hat I should set the permissions on my directories to?
Is this the same for PowerCMS and PowerStore and acceptable for all sites as a protocal? Thank you and I hope you had a wonderful Thanksgiving!
755 (Or Owner: Read Write Execute, Group: Read Execute, Public Read Execute) for directories
644 (Or Owner: Read Write, Group Read, Public Read) for files
should work as a general rule for all php sites.
