CMS add a linked file
Thread begun 11/17/2014 8:58 am by russb335115 | Last modified 11/24/2014 9:24 am by Jason Byrnes | 4061 views | 11 replies |
russb335115
I'm having an issue where when I add a PDF file to a link in Power CMS it is attaching the wrong address to the link?
russb335115
See PM
See PM
russb335115
See PM.
I am having the same issue with another website. Have you figured out what the problem is?
Looks like these sites are using an old version of the CKEditor, you should update the CKEditor version:
in the webassist/ folder, rename the ckeditor folder to ckeditor_bak
On this page:
download
click the button to launch CK Builder. Select to use the Full Preset, and the Kama Skin.
Copy the downloaded CKEditor folder to the webassist folder in your site.
from the ckeditor_back folder, copy the following three files:
ckeditor.php
ckeditor-php4.php
ckeditor-php5.php
and paste them in the new ckeditor folder.
you will need to clear the browsers cache to see the updates take effect.
russb335115
Did it an now the editor doesn't show up. So now the cms isn't usable. Please help
looks like the kama skin was not properly built in the down;road.
ont he contents update page, i commented the skin:
//$CKEditor_config["skin"] = "kama";
so it will use the default mono skin.
make sure you clear the browsers cache.
I see the link is still not working though, i am going to ask Ray to take a look, I'll let you know as soon as I hear something from him.
russb335115
Okay, thank you Jason.
Ray updated the kfm/plugins/return_url/plugin.js file t fix the problem, make a back up of that file to use on your other sites.
