HTML Editor: ancient forgotten slash "/" on kfm configuration file
Thread begun 11/13/2014 3:22 am by this_is_me | Last modified 11/13/2014 8:09 am by Jason Byrnes | 1183 views | 1 replies |
this_is_me
I can't remember how old it is, but the following error "survived" all updates. We use kfm extensions whenever we use HTML Editor to add files to the Text. A great function, indeed! The configuration file is contained in site-root subfolder:
/webassist/kfm/configuration.php (see attachments).
Each project gets its source from ->
C:\Users\UserName\AppData\Roaming\Adobe\Dreamweaver CSxx\en_US\Configuration\Shared\WebAssist\RichTextEditor\Source\kfm\configuration.php (version for Windows, MAC should be similar)
If the "/" is missing, path will be wrongly inserted. Could you please correct this? If not, all insertions will be something like:
/userfiles/path2imagesimage.jpg instead of /userfiles/path2images/image.jpg so that images won't show up.
Best,
tim
This is not truly the case for all servers. in many server environments, it will work with the slash for that setting.
In the near futire we are actually going to be moving away from KFM, it is pretty much a dead project that has not been updated for some time. We will be replacing it with CKFinder instead.
if adding the slash works for your projects, you can make the change in the main file:
to have it automatically added when use KFM. but is not truly a one size fits all fix, many don't need to have that slash added.
