Using add to cart button and getting errors on page
Thread began 11/13/2014 1:24 am by Blikbrein | Last modified 11/19/2014 10:11 am by Jason Byrnes | 1142 views | 10 replies |
Blikbrein
Please see page attached where I added the add to cart button. Error on page and does not display after adding button.
thanks for your help
Error:
Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /Users/marcelschmidt/Dropbox/Sites/novagen.co.za/Connections/novagen.php on line 9
Notice: Undefined variable: Novagen_Cart in /Users/marcelschmidt/Dropbox/Sites/novagen.co.za/products_detail.php on line 11
Fatal error: Call to a member function GetContent() on a non-object in /Users/marcelschmidt/Dropbox/Sites/novagen.co.za/products_detail.php on line 11
products_detail.php
The first error is happening because the error reporting level is set to report deprecated warnings. the php.ini file needs to be edited to set the error reporting level to not show deprecated warnings:
error_reporting = E_ALL & ~E_DEPRECATED
if you need help editing the php.ini file, contact your host.
for the other 2 errors, the cart object include line is using the virtual function.
change:
//WA eCart Include
virtual("/novagen.co.za/WA_eCart/Novagen_Cart_PHP.php");
//WA eCart Include
require_once("WA_eCart/Novagen_Cart_PHP.php");
The virtual function is being used because of a setting in your site definition.
In the site definition, there is a setting for "create links relative to"
When you set that to Site, DW uses the virtual function for include files, if you set that to Document instead, DW will use the require once function
Blikbrein
Thanks for getting back to me. I had the setting on document and not "create links relative to". Could it be a bug?
Please see page attached. Still getting error:
products_detail.php
Not a bug that I am able to reproduce, i have not seen DW use the virtual function unless the Site Create Links Relative to option is set to Site.
Blikbrein
See PM
I'm not able to reproduce the error you report, the error I see is different:
Parse error: syntax error, unexpected ')' in /home/dryrunco/public_html/novagen.co.za/WA_eCart/Novagen_Cart_PHP.php on line 88
this has to do with the tax rule. in the tax rule you have used the calculation:
Taxable Total Times 14%
you can't enter 14% in the calculation, you need to convert the percentage to a decimal number:
0.14
Taxable Total Times 0.14
Blikbrein
Tried to go into ECart and change 14% to 0.14 but it keeps crashing. Cleared the cache. Tried to delete the Tax entry completely - crashed. Yosemite with CC 2014.1.
This is a compatibility issue with Mac OS Yosemite. I Updated the tax rule in the code for you to fix the problem.
i changed:
function WAEC_Novagen_Cart_VAT()  {
$totalTax = 0;
if (true && ((sizeof($this->Items) == 0))) {
$totalTax += ($this->TotalColumn("TotalPrice") * 14%);//Result
return WA_eCart_FormatNumber($totalTax, $this->ForceDecimalsC, $this->DecimalPlacesC);
$totalTax = 0;
if (true && ((sizeof($this->Items) > 0))) {
$totalTax += ($this->TotalColumn("TotalPrice") * 0.14);//Result
Blikbrein
Thanks Jason. you're a star! I will look into the other issue today and let you know.
Blikbrein
Now please check for me why I am getting this error:
Notice: Undefined variable: Novagen_Cart in /home/dryrunco/public_html/novagen.co.za/products_detail.php on line 11
Fatal error: Call to a member function GetContent() on a non-object in /home/dryrunco/public_html/novagen.co.za/products_detail.php on line 11
Thanks!
