JavaScript Error
When I open a page or try to save it, I'm getting a JavaScript error. Please see attachment.
I've already un- and reinstalled DB, DA and eCart.
i don't speak german, can you translate the message please.
also, what is your OS and what extensions including the version numbers are installed. Please list the version numbers rather than stating they are current.
I try to translate it:
"A JavaScript error occured while loading Recordset.htm: Script file ".../FieldTypes.js" can not be opened. Error 2"
I've attached to extension list in pm
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
in the users configuration folder where you delete the cache file go to:
ServerBehaviors/PHP_MySQL
abd paste the attached fieldtypes.js file.
