unable to clear cart
Thread begun 11/08/2014 2:24 pm by Warrio | Last modified 11/11/2014 7:33 pm by Warrio | 1289 views | 2 replies |
Warrio
I've used session destroy, the webassist server behaviour for clear cart and a few others, none of it clears the cart!
Any ideas
Cheers
Norman
Is the cart set to use a cookie?
if the session destroy code does not clear the cart, the 2 possibilities are:
the Cart uses a cookie, or the session destroy code is not being run. it may be added inside another code block, or a page that is not being accessed.
Warrio
the cart uses sessions and the page has session destroy which in the past has worked, for some reason it doesn't anymore, I'll check out your suggestions
Thanks again
