Uploading error
Thread began 11/07/2014 4:53 pm by Ericspecullaas | Last modified 12/12/2014 2:25 pm by Ericspecullaas | 1605 views | 6 replies |
Ericspecullaas
Uploading error
Greetings Jason
im getting an error on line 74 of the helperphp.php file. Im getting this error "Parse error: syntax error, unexpected '[' in /home/betatestpage/www/www/valleywound/webassist/file_manipulation/helperphp.php on line 74"
here is the offending code
$fileArray = array();
if (is_array($_FILES[$fileField]['tmp_name'])) {
for ($x=0; $x<sizeof($_FILES[$fileField]['tmp_name']); $x++) {
if (is_uploaded_file($_FILES[$fileField]['tmp_name'][$x])) $fileArray[] = ['tmp_name'=>$_FILES[$fileField]['tmp_name'][$x],'name'=>$_FILES[$fileField]['name'][$x],'type'=>$_FILES[$fileField]['type'][$x],'size'=>$_FILES[$fileField]['size'][$x]];
} else {
if(isset($_FILES[$fileField]) && is_uploaded_file($_FILES[$fileField]['tmp_name'])) $fileArray[] = $_FILES[$fileField];
i have used the upload feature prefectly on a few projects but not sure whats going on. I have removed it to help with uploading but its removing the photo upload part that is need for just about everything. I am running php 5.3.29 and my data bridge is up to date.
thanks,
Eric
helperphp.php
attached is an updated copy of the webassist/file_manipulation/helperphp.php file that has the issue corrected.
helperphp.php.zip
Ericspecullaas
thank you
you're welcome.
Ericspecullaas
it happened again
Parse error: syntax error, unexpected '[' in /home/betatestpage/www/a-and-l-labs/webassist/file_manipulation/helperphp.php on line 74
thanks in advance
not really sure why this keeps happening to file uploads
helperphp.php
use the helper.php file I attached in message 2:
http://www.webassist.com/forums/post/183283/
Ericspecullaas
ok thanks not sure why it keeps failing
