Use Security Assist to build MySQL Table?
Thread begun 11/06/2014 12:11 pm by randyrie405335 | Last modified 11/19/2014 10:35 am by Jason Byrnes | 4082 views | 7 replies |
randyrie405335
I can successfully create a suite of logon PHP pages if I allow Security Assist to build the MySQL table. However, even though SA recognizes my previously built MySQL tables, I cannot enter data via the registration form - I get blank fields (not NULLs) in the dB table. I'm trying to use a 'hash' so the data is encrypted -- which works fine if I allow SA to build the table but does NOT work if I try to use a previously built table. Must I re-configure the existing MySQL tables into some other format (I prefer using utf-8)? Or must I allow SA to build any MySQL tables that I need?
If you use your own table, then you will need to use the New From Blank preset and configure all of the settings on the manager pages tab for the fields and for the pages to be created.
If you select to use one of the existing presses, those are configured for the tables that security assist will create and won't match your existing table.
randyrie405335
Using Your Out-Dated Data Bridge
OSX 10.9.5, DW CS6, DB v.1.2.1, MySQLi v.1.0.3
When will the MySQLi compatible version of Data Bridge be released?
I am having a terrible time trying to build a complete Security Assist (SA) suite of web pages using the current Data Bridge version (v. 1.2.1). I am going round-and-round with the now out-dated Data Bridge, trying to get it to work with a website I just built using MySQLi. Particularly the "Forgot Password" feature - I don't know how to tie this into my logon page.
Perhaps I'm not completely understanding your GUI input forms. Do you have available a step-by-step tutorial of how a complete SA suite of pages are built?
We are targeting the First Quarter of next year for Data Bridge with MySQLi
I don't follow what you mean by:
"I don't know how to tie this into my logon page."
On the login page would be a link to the forgot password page.
the forgot password page would have an form on it to enter the email address for the user.
this form when submited would send the email to the email password sever behavior.
to use the email password server behavior, you will need a regular MySQL connection.
On the Database tab, select the MySQL connection and the users table.
for the lookup column select the email address column, for the lookup value, click the lightning bolt icon and select the email address form element.
For the username and password columns, select the columns used by the login behavior for user name and password.
There is not a step by step tutorial for this.
randyrie405335
Thanks for the tips. I'll step through these and see if I can this all to work.
you're welcome.
randyrie405335
Another Question
My client is requiring all data stored in his MySQL database be encrypted and also requires some reports that will pull this data out and thus needs to be decrypted. I can get the data to be stored in the dB encrypted using Security Assist but how do I create a report with tables displaying the data decrypted?
Create recordset to return the data to the page.
use the bindings panel to add the recordset column to the page. highlight the recordset binding code on the page, and go to the bindings panel, that column will be highlighted, and there will be a format drop down list. select the corresponding Decryption format to match the encryption method you selected.
