email doesn´t work Webassist Email Mesagge
Thread begun 11/05/2014 11:44 am by QuiruNet | Last modified 11/05/2014 11:51 am by Jason Byrnes | 1055 views | 1 replies |
QuiruNet
http://lapostboda.es/clientes.php
on the registration form, I have automatic email behavior, if a new user is registered, an email will be sent information with their data, but the email is not sent ... do not know why ... before the site was on another server and it worked normally, but now doesnt work anymore.
Who is your host?
Depending on your host, you may need to set certain options in Universal Email.
Some hosts will work if you leave the SMTP Server setting on the Email Server Tab blank, others will require that you enter the SMTP server address.
Some will work using the standard Mail protocol, other will require that you use the Pear Mail for SMTP, some using Pear mail will require authentication.
Some hosts may require that the from address being used be a valid email address for your domain. Some may require that the option to include the from Email address be passed as an extra parameter.
To be successful with Universal Email, you will need to know the requirements of your host for sending an email using a PHP script.
Also, double check your Spam folder, it is possible that the email is being trapped as spam.
