Admin CMS Pages are blank, KFM uploader will not work, will not save changes except in source mode
Thread begun 11/05/2014 9:43 am by jo271221 | Last modified 11/18/2014 2:34 pm by Jason Byrnes | 5859 views | 9 replies |
jo271221
Admin CMS Pages are blank, KFM uploader will not work, will not save changes except in source mode. TownOfOsceola.com
FTP and CMS Admin info are attached.
Please use admin_cms/indexBU.php as I updated the index to kind of get us by.
See PM
jo271221
I have another compromkised site that uses CMS Builder
Feeling very frustrated, nervous and unprofitable. Maybe I should have chosen to be a word press or joomla expert - ? Please help.
the permissions on the WA_CMS/WA_CMS.php are set to none. and using the FTP info you have provided, I am not able to change those permissions.
The permissions level of 755 should be good for directories and 644 should be good for files. The host will need to edit the permissions for that file, as I am not able to.
The CMS Admin username and password you are using is not really very strong. by using weak passwords and a pretty generic username, the CMS system is vulnerable to a brute force attack where a bot basically just tries every combination till it gets in
jo271221
CMS blank pages
I adjusted the permissions on that file and I now I am back to getting a blank page on the home page western-wishes.com
I found that the WA_CMS/WA_CMS.php file had hacked code in it, i uploaded a fresh copy of that file.
I also found the webassist/security_assist/helper_php.php and webassist/database_management/wa_appbuilder_php.php files had permissions set to 000, i uploaded fresh copies of those files to fix the problem.
jo271221
Admin CMS Index is blank
Thank You! Now the Admin page is blank. I pulled it from the server to check for the malicious code and I don't see it.
The templates/admin.dwt.php page had the hacked code on it, i uploaded a fresh copy, and the CSSMenuWriter/cssmw_cms/menu.php file had the 000 permissions, i uploaded a fresh copy of that file too.
jo271221
Thank You!
you're welcome.
