This is really a CCS question but I used DataAssist So...
Thread begun 11/03/2014 11:19 am by vernon webb | Last modified 11/03/2014 12:35 pm by vernon webb | 2055 views | 5 replies |
vernon webb
I'm sure this is a pretty simple question to answer and thought as opposed to spending hours to try and figure it out maybe some had a quick answer. I have used the Sidebar style sheet to create a results page. I am hoping there is an easy way to have the search box on the page stay on the left while results stay on the right as apposed to below as shown in the attached photo?
please send a link
for CSS questions, a link is a must.
i think what i would do, is not use the option to have the search page on the results page, but rather use framework builder plugins
create a new page with a div for the search box and a div for the results, then use framework builder plugins to add the search page as a plugin in the search box, and add the results page as a plugin in the results box.
vernon webb
Never mind. Was hoping for a simple solution.
MikeyT
Possible solution:
Float the Search Field's parent container to the left. Possible CSS follows:
.searchContainerClassName {float:left; width:yourSearchContainerWidth;}
Then float the Results area's parent container to the right. Finally, change the width of the Results area's parent container so that it equals the difference between the Search Field's parent container and the page width (ie. Search Field container width minus page width = Results are container width). Possible CSS follows:
.resultsContainerClassName {float:right; width:yourResultsContainerWidth;}
This is one approach. Note: floats can be a tricky endeavor.
vernon webb
Thank you
