Insert record behavior disappeared.
My Insert record behavior disappeared from the code. It may be a coincidence, but I just installed the new Data Bridge 1.2.1 and eCart extension 6.1.0. I thought the behavior was working after installing Data Bridge but now after installing eCart noticed it isn't.
I also had an error when I opened the file. Dynamic select list script does not define find server behaviors function
I reset the workplace and deleted the configuration file.
I have attached the file.
