eCart stop working - asking for activation again
Thread begun 11/01/2014 9:21 am by ccdantas101117 | Last modified 11/05/2014 10:45 am by Jason Byrnes | 1925 views | 6 replies |
ccdantas101117
eCart stop working - UNEXPECTED ACTIVATION ERRO:0
eCart 4.05 keeps asking for activation code - I reset the activation under my account enter the numbers and it keeps not activating showing unexpected error:0 i don't know what to do - I need this to work so I can keep working with the site on my Dreamweaver. Sending attached the error (print screen)
I deleted part of the registration code and left the last for digits and the green ticker
ccdantas101117
Please I need help - Can anybody from webassist in the forum help? I send message to sales, and called...
Int he private message section, send the serial numbers and the Mac Address for your computer and include your email address, I can use that to generate the licenses files for you to activate manually.
On windows, To find out the MAC address:?
1) Go to the Start Menu -> Run. Type "cmd" and click on OK to bring up a command prompt.?
2) At the command prompt type "ipconfig /all > c:\\ipconfig.txt"?This will create a file in your C drive called ipconfig.txt. This file will have the MAC address in it.
On Mac:
1) Open System Preferances
2) Go To Network
3) in the list of connections, select the active one, and click the advanced button
4) Go to the Ethernet tab and note the Ethernet ID
ccdantas101117
On Mac:
2) Go To Network
Lincese files have been sent to your email
this_is_me
Please help me on the same issue
Can't work for days!!!!
What is the exact error you are getting?
What extension, including the version number are you activating?
