Image Re-size
Thread begun 10/31/2014 6:57 pm by mycalidesigns | Last modified 11/03/2014 9:54 am by Jason Byrnes | 1463 views | 2 replies |
mycalidesigns
Image Re-size
I am using image resize to dynamically size images, it works when i set the image attributes width and height but i want to use css to set the size i want.
Please help.
Jamie
Image Resizer only works when you specify the dimensions in the <img> tag so using the css to do this wouldn't work
All the best
Jamie
Jamie is correct, image resizer looks at the width and height attributes of the image tag to determine the dimensions it should use, it will not work if you use CSS for these attributes.
