Two ATCs from different recordsets on same page
Thread begun 10/28/2014 10:40 am by jlowery | Last modified 10/29/2014 9:29 am by Jason Byrnes | 3090 views | 5 replies |
jlowery
My client is transitioning to a mobile site where I need to combine the ATC buttons from 2 separate recordsets (previously on separate pages) on to a single page with a tabbed interface. I'm using ECart 5. Is this possible?
Thanks - Joe
I don't see why this wouldn't work, just make sure to select the correct recordset in each add to cart button behavior.
jlowery
Maybe I'm doing it wrong, but when I choose to insert a new Add to Cart server behavior, I don't see an option to select from a recordset. Would I choose Get Contents from Recordset instead?
use Webassist -> eCart -> Add to cart
jlowery
Okay, now I'm getting a "can't put this inside an existing form" and when I move outside of the form, I get this error message:
While executing onClick in WA eCart AddToCart.htm, the following JavaScript error(s) occurred:
At line 915 of file "Macintosh HD:Users:josephlowery:Library:Application Support:Adobe:Dreamweaver CS6:en_US:Configuration:Commands:WA eCart AddToCart.js":
document.generalWP.document.column.options[document.generalWP.document.column.selectedIndex] has no properties
I've attached the page I'm working with. You'll see two tabs, the second tab (starting on line 224) holds the cart display area I'm trying to get working with recordset rsSavory. The problem might be I'm trying to put two cart displays on the same page. Is that feasible?
Yes, when you add the add to cart button, it will add the button form to the page along with the behavior, so you need to add it outside of any existing forms.
What version of eCart do you have installed? are you using eCart 6? make sure you have the latest version installed that is available in your download center.
also, reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
