ecart bug?
Thread begun 10/26/2014 10:21 am by Ericspecullaas | Last modified 10/27/2014 12:36 pm by Jason Byrnes | 2483 views | 3 replies |
Ericspecullaas
ecart bug?
Greetings jason,
im calling this a bug because how the cart script read 2 commands at the same time. on this page http://www.disasterresistantconsulting.com/preparedness-test.php when I add an item it works prefectly, but if I were to change the cart value to 2 then change the shipping radio to Priority shipping then update the cart it doesn't add the math correctly. but if a add 1 item more then update then click priority then update it add up just fine not sure whats really going on or if I should even be worried.
thanks from Eric
Ericspecullaas
pm sent
This isn't a bug in the cart it is a bug in the way you are setting up shipping.
in the cart page, you are dynamically setting the name of the priority form element based on the quantity in the cart:
input name="upgrade<?php echo $eCart1->DisplayInfo("Quantity"); ?>" type="radio" value="priority<?php echo $eCart1->DisplayInfo("Quantity"); ?>" id="priority<?php echo $eCart1->DisplayInfo("Quantity"); ?>" />
this means that if the quantity in the cart is 1, the form element is named "upgrade1", you are then setting a session named upgrade 1 and using that for the shipping, doesn't matter if you change the quality, it will still be named upgrade1 when you clic the update button.
