Shipping missing in Database-driven shipping.
Thread begun 10/23/2014 7:23 pm by jsnwang89407861 | Last modified 10/24/2014 11:11 am by Jason Byrnes | 4110 views | 5 replies |
jsnwang89407861
I tried to set up database-driven shipping based on Jason's suggestions, however the shipping information is not shown on Confirm Page.
The following is my steps,
In my database, I have the following columns in table ShippingRate:
shipingRateID - Primary Key, Auto Number
shippingRateCountry - 2 letter country code: GB, US, CA etc.
shippingBase - this will store the base rate for the country, $45 for US
on the confirm page, create a shipping rate lookup recordset.
Set the filtering options to filter the shippingRateCountry equal Form Variable 'shipping_country'
Now add a Session Value server behaviors for
shippingBase
Set the trigger to Any Form Post.
Set the name to be the same as the database column
Click the lightning bolt next to value and select the corresponding column from the recordset.
Then,
On the shipping tab create the base rule:
trigger: Total Number of items > 0
calculation: Flat Rate:
$_SESSION['ShippingBase']
Only GrandTotal without shipping is shown on confirm page. Could you help me out with the problem of missing shipping ?
Thank you,
Dave
shippingBase
you don't show the code for setting the session, but in you say is set using a lower case leading s, but in the calculation you use an upper case leading S. PHP is case sensitive, so if it is set using lower case, the session reference should use lower case also:
$_SESSION['shippingBase']
jsnwang89407861
Thanks Jason.
In the code, I actually did use the same name as ShippingBase.
Please see attached code.
Dave
The code to set the ShippingBase session comes before the rsShippingrate recordset.
you will need to move the code that sets the session to be after the recordset.
jsnwang89407861
Jason,
That works!
Thank you very much!
Dave
you're welcome.
