Installing Webassist extensions in Dreamweaver CC.
Thread begun 10/20/2014 12:30 pm by tmcbinc99963 | Last modified 10/20/2014 12:52 pm by Jason Byrnes | 1206 views | 1 replies |
tmcbinc99963
I am currently using Mac OS 10.85 running CS3 and CC Dreamweaver applications, using no other extensions. I would like to use my existing Webassist extensions for either application.
Extension Manager CS3 crashes in Mountain Lion; but can use all other CS3 applications. How do I install the Webassist extensions into DW CS3 using Mountain Lion?
For CC, I first converted the old .mxp file into a new .zxp file using Extension Manager CS6 as advised by Adobe. When trying to install the new .zxp file using Extension Manager CC, I get a 'failed to update database' error. How do I install the Webassist extensions into DW CC?
To use our extensions in DW CC, you would need to upgrade to the most recent versions:
Design Extender
Data Bridge
eCart 6
These extensions are not compatible with DW CS3 though.
so you would need to continue using the old extensions in CS3. we d not have versions that are compatible with both CS3 and DW CC.
To install the extension in DW CS3, you would need to fix the extension manager issue with Adobe so that you can use the CS3 extension manager.
